跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
The speaker can be easily removed from the back cover.
配件
没有特定配件。
  1. Remove the four rubber caps from the back by using the Philips #00 screwdriver to pull them from the back. Remove the four rubber caps from the back by using the Philips #00 screwdriver to pull them from the back.
    • Remove the four rubber caps from the back by using the Philips #00 screwdriver to pull them from the back.
  2. Remove the four screws holding the cover in place by using the Phillips #00 screwdriver.
    • Remove the four screws holding the cover in place by using the Phillips #00 screwdriver.
  3. Remove the back cover from the device by separating the back cover along its seam. Slowly lift the cover, the speaker is screwed onto the back cover and is connected onto the circuit board.
    • Remove the back cover from the device by separating the back cover along its seam.
    • Slowly lift the cover, the speaker is screwed onto the back cover and is connected onto the circuit board.
  4. Pull the speaker cord, horizontally, by its base, away from the motherboard. When reassembling, make sure that you plug the terminal in the same way.  The black wire should be on the side farthest from the battery.
    • Pull the speaker cord, horizontally, by its base, away from the motherboard.
    • When reassembling, make sure that you plug the terminal in the same way. The black wire should be on the side farthest from the battery.
  5. Once you pull off the back cover, remove the orange piece of tape on the speaker. Use a Philips #00 screwdriver to remove the 2 screws holding the speaker to the back casing. Use a Philips #00 screwdriver to remove the 2 screws holding the speaker to the back casing.
    • Once you pull off the back cover, remove the orange piece of tape on the speaker.
    • Use a Philips #00 screwdriver to remove the 2 screws holding the speaker to the back casing.
  6. Once the speaker has been unscrewed, remove the speaker from the back casing with your fingers.
    • Once the speaker has been unscrewed, remove the speaker from the back casing with your fingers.
结论
Ross Light
于2010年04月12日注册
175 信誉积分
创作了6篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 2,259
