跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
Magellan RoadMate 1200 Motherboard Replacement
你所需要的
  1. Magellan RoadMate 1200 Motherboard Replacement, Back Cover: 步骤 1 中的图像 1,2 Magellan RoadMate 1200 Motherboard Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Remove the four rubber caps from the back by using the Phillips #00 screwdriver.
  2. Magellan RoadMate 1200 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Remove the four screws holding the cover in place by using the Phillips #00 screwdriver.
  3. Magellan RoadMate 1200 Motherboard Replacement: 步骤 3 中的图像 1,2 Magellan RoadMate 1200 Motherboard Replacement: 步骤 3 中的图像 2,2
    • Remove the back cover from the device by separating the back cover along its seam.
    • Slowly lift the cover—the speaker is screwed onto the back cover and is connected to the circuit board.
  4. Magellan RoadMate 1200 Motherboard Replacement: 步骤 4 中的图像 1,2 Magellan RoadMate 1200 Motherboard Replacement: 步骤 4 中的图像 2,2
    • Pull the speaker cord, horizontally, by its base, away from the motherboard.
    • When reassembling, make sure that you plug the terminal in the same way. The black wire should be on the side farthest from the battery.
  5. Magellan RoadMate 1200 Motherboard Replacement, Motherboard: 步骤 5 中的图像 1,1
    • Remove the two screws on that are located on opposite sides of the board.
  6. Magellan RoadMate 1200 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Lift up the circuit board and disconnect the GPS wire, pulling horizontally from its connector port.
结论
另外一个人完成了本指南。
Ross Light
于04/12/10注册
217 声望
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 5,010
