跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
This guide will outline how to replace a Magellan RoadMate 1200 motherboard. This piece is an integral part to the system, and may malfunction or break after a long period of use.
配件
没有特定配件。
  1. Remove the four rubber caps from the back by using the Phillips #00 screwdriver. Remove the four rubber caps from the back by using the Phillips #00 screwdriver.
    • Remove the four rubber caps from the back by using the Phillips #00 screwdriver.
  2. Remove the four screws holding the cover in place by using the Phillips #00 screwdriver.
    • Remove the four screws holding the cover in place by using the Phillips #00 screwdriver.
  3. 任天堂 Switch 套装
    A quick fix to get back in the game
    Shop Switch Kits
    任天堂 Switch 套装
    Shop Switch Kits
  4. Remove the back cover from the device by separating the back cover along its seam. Slowly lift the cover—the speaker is screwed onto the back cover and is connected to the circuit board.
    • Remove the back cover from the device by separating the back cover along its seam.
    • Slowly lift the cover—the speaker is screwed onto the back cover and is connected to the circuit board.
  5. Pull the speaker cord, horizontally, by its base, away from the motherboard. When reassembling, make sure that you plug the terminal in the same way.  The black wire should be on the side farthest from the battery.
    • Pull the speaker cord, horizontally, by its base, away from the motherboard.
    • When reassembling, make sure that you plug the terminal in the same way. The black wire should be on the side farthest from the battery.
  6. Remove the two screws on that are located on opposite sides of the board.
    • Remove the two screws on that are located on opposite sides of the board.
  7. Lift up the circuit board and disconnect the GPS wire, pulling horizontally from its connector port.
    • Lift up the circuit board and disconnect the GPS wire, pulling horizontally from its connector port.
结论
另外一个人完成了本指南。
Ross Light
于2010年04月12日注册
175 信誉积分
创作了6篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 6
过去的30天: 11
总计 4,893
