当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Remove the four rubber caps from the back by using the Phillips #00 screwdriver.
Remove the four screws holding the cover in place by using the Phillips #00 screwdriver.
Remove the back cover from the device by separating the back cover along its seam.
Slowly lift the cover—the speaker is screwed onto the back cover and is connected to the circuit board.
Pull the speaker cord, horizontally, by its base, away from the motherboard.
When reassembling, make sure that you plug the terminal in the same way. The black wire should be on the side farthest from the battery.
Remove the two screws on that are located on opposite sides of the board.
Lift up the circuit board and disconnect the GPS wire, pulling horizontally from its connector port.
Carefully flip the circuit board out so you can get to the sensor easily.
Remove the tape holding the sensor to the display and take out the sensor.
取消:我没有完成这个指南。
另外一个人完成了本指南。
与5其他贡献者
于04/12/10注册
217 声望
创作了6篇指南
徽章: 12
+ 9更多徽章
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 6
总计 3,138
