跳转到主内容
Magellan RoadMate 1200 Display Replacement
你所需要的
  1. Magellan RoadMate 1200 Display Replacement, Back Cover: 步骤 1 中的图像 1,2 Magellan RoadMate 1200 Display Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Remove the four rubber caps from the back by using the Phillips #00 screwdriver.
  2. Magellan RoadMate 1200 Display Replacement: 步骤 2 中的图像 1,1
    • Remove the four screws holding the cover in place by using the Phillips #00 screwdriver.
  3. Magellan RoadMate 1200 Display Replacement: 步骤 3 中的图像 1,2 Magellan RoadMate 1200 Display Replacement: 步骤 3 中的图像 2,2
    • Remove the back cover from the device by separating the back cover along its seam.
    • Slowly lift the cover—the speaker is screwed onto the back cover and is connected to the circuit board.
  4. Magellan RoadMate 1200 Display Replacement: 步骤 4 中的图像 1,2 Magellan RoadMate 1200 Display Replacement: 步骤 4 中的图像 2,2
    • Pull the speaker cord, horizontally, by its base, away from the motherboard.
    • When reassembling, make sure that you plug the terminal in the same way. The black wire should be on the side farthest from the battery.
  5. Magellan RoadMate 1200 Display Replacement, Motherboard: 步骤 5 中的图像 1,1
    • Remove the two screws on that are located on opposite sides of the board.
  6. Magellan RoadMate 1200 Display Replacement: 步骤 6 中的图像 1,1
    • Lift up the circuit board and disconnect the GPS wire, pulling horizontally from its connector port.
  7. Magellan RoadMate 1200 Display Replacement, Logic Board: 步骤 7 中的图像 1,2 Magellan RoadMate 1200 Display Replacement, Logic Board: 步骤 7 中的图像 2,2
    • Peel back the tape securing the display connector to the logic board.
  8. Magellan RoadMate 1200 Display Replacement: 步骤 8 中的图像 1,1
    • Remove the display connector from the device.
    • Do not pull on the cable because you may damage it. Instead, try to pull as closely as you can to the plug.
  9. Magellan RoadMate 1200 Display Replacement, GPS Sensor: 步骤 9 中的图像 1,2 Magellan RoadMate 1200 Display Replacement, GPS Sensor: 步骤 9 中的图像 2,2
    • Carefully flip the circuit board out so you can get to the sensor easily.
    • Remove the tape holding the sensor to the display and take out the sensor.
  10. Magellan RoadMate 1200 Display Replacement, Display: 步骤 10 中的图像 1,3 Magellan RoadMate 1200 Display Replacement, Display: 步骤 10 中的图像 2,3 Magellan RoadMate 1200 Display Replacement, Display: 步骤 10 中的图像 3,3
    • Undo the 4 clasps holding the display in place.
    • Pop the display from the front cover.
结论
另外一个人完成了本指南。
Ross Light
于04/12/10注册
217 声望
创作了6篇指南
一条评论
In order to remove the rubber plugs hiding the 4 screws, I found that a straight pin angled into the top of the plug can be used to lift them easily straight out and the plug is unharmed.
With the screws out, the back did not budge. I used the thinest blade screw driver in my jeweler's set to pry the case open and pushed on the plastic catches, one on each side that were holding it closed. They are visible in the photo of the back off.
Jomar - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 3,444
