跳转到主内容
MagLite 4D O-Ring Replacement
  1. MagLite 4D O-Ring Replacement, O-ring: 步骤 1 中的图像 1,1
    • Unscrew the Maglite head.
    • Remember, to unscrew a flashlight head, turn it counterclockwise.
  2. MagLite 4D O-Ring Replacement: 步骤 2 中的图像 1,1
    • Remove the lens.
  3. MagLite 4D O-Ring Replacement: 步骤 3 中的图像 1,1
    • Remove the reflector cone.
  4. MagLite 4D O-Ring Replacement: 步骤 4 中的图像 1,1
    • Examine the O-ring for damage.
    • The O-ring is the black rubber band around the flashlight head.
  5. MagLite 4D O-Ring Replacement: 步骤 5 中的图像 1,1
    • Remove the damaged O-ring.
    • The O-ring is flexible, so it should be easy to pull off. Or, it may fall off if it is broken.
  6. MagLite 4D O-Ring Replacement: 步骤 6 中的图像 1,1
    • Place the new O-ring in the same place as the original.
    • The O-ring is flexible, so simply pull it on gently.
  7. MagLite 4D O-Ring Replacement: 步骤 7 中的图像 1,1
    • Wipe the moisture from the reflector cone with a paper towel or soft cloth.
  8. MagLite 4D O-Ring Replacement: 步骤 8 中的图像 1,1
    • Wipe the moisture from the lens with a paper towel or soft cloth.
  9. MagLite 4D O-Ring Replacement: 步骤 9 中的图像 1,1
    • Replace the reflector cone.
    • Replace the lens.
  10. MagLite 4D O-Ring Replacement: 步骤 10 中的图像 1,1
    • Screw on the Maglite head.
    • Remember, to screw on a flashlight head, turn it clockwise.
  11. MagLite 4D O-Ring Replacement: 步骤 11 中的图像 1,1
    • Test the Maglite by turning it on.
    • If your Maglite turns on, your work is complete!
结论
If your Maglite turns on, it should be ready to go! If your Maglite does not turn on, the next step is to look at the battery compartment. Please see another guide for this step.
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 13
过去 30 天: 41
总计 1,247
