跳转到主内容
Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement
你所需要的
  1. Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement, Joystick: 步骤 1 中的图像 1,1
    • Unplug your controller from your console or pc.
  2. Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: 步骤 2 中的图像 1,3 Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: 步骤 2 中的图像 2,3 Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: 步骤 2 中的图像 3,3
    • Remove the four 3mm screws with a Philips #0 screwdriver.
  3. Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: 步骤 3 中的图像 1,3 Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: 步骤 3 中的图像 2,3 Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: 步骤 3 中的图像 3,3
    • Remove the six 0.9mm screws with a Phillips #00 screwdriver.
  4. Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: 步骤 4 中的图像 1,2 Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: 步骤 4 中的图像 2,2
    • Remove the metal plate cover.
    • Find the lever inside of the controller.
  5. Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: 步骤 5 中的图像 1,3 Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: 步骤 5 中的图像 2,3 Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: 步骤 5 中的图像 3,3
    • Insert your Flathead screwdriver into the middle of the lever to hold it in place.
    • Twist the ball to remove it from the lever.
    • Remove the ball top from the lever.
  6. Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: 步骤 6 中的图像 1,2 Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: 步骤 6 中的图像 2,2
    • Remove the four 1.1mm screws holding the lever in place with your Phillips #0 screwdriver.
  7. Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: 步骤 7 中的图像 1,1
    • Remove the lever from the casing of the controller.
  8. Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: 步骤 8 中的图像 1,2 Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: 步骤 8 中的图像 2,2
    • Pull the cable connected to the lever out of the socket.
    • Remove the lever from the case.
结论
另外一个人完成了本指南。
Jordan
于07/06/21注册
184 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 22
过去 30 天: 81
总计 1,582
