简介
Use this as a guide to replace or remove the rear case.
  1. Use tweezers to completely remove the sticker from the rear of controller.
    • Use tweezers to completely remove the sticker from the rear of controller.
  2. Find the seven 8.3 mm Phillips screws on the rear of the controller and remove them.
    • Find the seven 8.3 mm Phillips screws on the rear of the controller and remove them.
  3. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  4. Use a plastic opening tool to separate the rear and front casing by inserting it in-between the two cases. Use the plastic opening tool to pry the two cases apart.
    • Use a plastic opening tool to separate the rear and front casing by inserting it in-between the two cases.
    • Use the plastic opening tool to pry the two cases apart.
  5. Remove the two rubber side grips. Remove the two rubber side grips.
    • Remove the two rubber side grips.
结论
另外一个人完成了本指南。
Jefferson Hsu
于2012年09月18日注册
408 信誉积分
创作了3篇指南
团队
Cal Poly, Team 1-7, Propen Fall 2012 Cal Poly, Team 1-7, Propen Fall 2012 的会员
CPSU-PROPEN-F12S1G7
4 名成员
创作了7篇指南
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 3
总计 742
