跳转到主内容
Mad Catz Street Fighter IV FightPad Directional Pad Replacement
你所需要的
  1. Mad Catz Street Fighter IV FightPad Directional Pad Replacement, Rear and Side Case: 步骤 1 中的图像 1,1
    • Use tweezers to completely remove the sticker from the rear of controller.
  2. Mad Catz Street Fighter IV FightPad Directional Pad Replacement: 步骤 2 中的图像 1,1
    • Find the seven 8.3 mm Phillips screws on the rear of the controller and remove them.
  3. Mad Catz Street Fighter IV FightPad Directional Pad Replacement: 步骤 3 中的图像 1,2 Mad Catz Street Fighter IV FightPad Directional Pad Replacement: 步骤 3 中的图像 2,2
    • Use a plastic opening tool to separate the rear and front casing by inserting it in-between the two cases.
    • Use the plastic opening tool to pry the two cases apart.
  4. Mad Catz Street Fighter IV FightPad Directional Pad Replacement: 步骤 4 中的图像 1,2 Mad Catz Street Fighter IV FightPad Directional Pad Replacement: 步骤 4 中的图像 2,2
    • Remove the two rubber side grips.
  5. Mad Catz Street Fighter IV FightPad Directional Pad Replacement, RS-DP-LS Switch: 步骤 5 中的图像 1,2 Mad Catz Street Fighter IV FightPad Directional Pad Replacement, RS-DP-LS Switch: 步骤 5 中的图像 2,2
    • Locate RS-DP-LS switch.
    • Pull upwards on the switch to remove it.
  6. Mad Catz Street Fighter IV FightPad Directional Pad Replacement, Circuit Board: 步骤 6 中的图像 1,1
    • Locate the four 8.3 mm Phillips screws on the circuit board and remove them.
  7. Mad Catz Street Fighter IV FightPad Directional Pad Replacement: 步骤 7 中的图像 1,3 Mad Catz Street Fighter IV FightPad Directional Pad Replacement: 步骤 7 中的图像 2,3 Mad Catz Street Fighter IV FightPad Directional Pad Replacement: 步骤 7 中的图像 3,3
    • Hold the controller cable at the area just before it meets the controller and slowly lift upwards to slide it out of its plastic slot and remove the circuit board.
    • Be careful with the wires connected to the circuit board itself as they are thin and delicate.
    • When reassembling the controller, make sure that the bottom plastic piece is fully inserted into its slot before replacing the circuit board.
  8. Mad Catz Street Fighter IV FightPad Directional Pad Replacement, Directional Pad: 步骤 8 中的图像 1,1
    • Use tweezers to remove the rubber part of the directional pad.
  9. Mad Catz Street Fighter IV FightPad Directional Pad Replacement: 步骤 9 中的图像 1,2 Mad Catz Street Fighter IV FightPad Directional Pad Replacement: 步骤 9 中的图像 2,2
    • Insert a new directional pad over the original directional pad's location.
结论
2等其他人完成本指南。
Jefferson
于09/26/12注册
78 声望
撰写一个指南
团队
Cal Poly, Team 1-7, Propen Fall 2012 Cal Poly, Team 1-7, Propen Fall 2012 的会员
CPSU-PROPEN-F12S1G7
4 名成员
创作了14篇指南
2条评论
mi spiegate l'utilita di questa guida?vendere forse le pinzette e tutte le altre stronzatine che servono per riparare il fightpad?quando invece il pezzo più importante cioè il gommino non lo vendete....fate pena
auredo1988 - 回复
Hi I don't speak Italian but I think you are asking "what is the purpose of this guide?". We made these as a project for university because I wanted to resolder a wire in this controller that came undone. For good measure we made a guide for each individual part although the real purpose of these guides was for the full disassembly and re soldering.
Eric Devlin - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 14
总计 4,429
