跳转到主内容
Mad Catz Street Fighter IV FightPad Circuit Board Replacement
你所需要的
  1. Mad Catz Street Fighter IV FightPad Circuit Board Replacement, Rear and Side Case: 步骤 1 中的图像 1,1
    • Use tweezers to completely remove the sticker from the rear of controller.
  2. Mad Catz Street Fighter IV FightPad Circuit Board Replacement: 步骤 2 中的图像 1,1
    • Find the seven 8.3 mm Phillips screws on the rear of the controller and remove them.
  3. Mad Catz Street Fighter IV FightPad Circuit Board Replacement: 步骤 3 中的图像 1,2 Mad Catz Street Fighter IV FightPad Circuit Board Replacement: 步骤 3 中的图像 2,2
    • Use a plastic opening tool to separate the rear and front casing by inserting it in-between the two cases.
    • Use the plastic opening tool to pry the two cases apart.
  4. Mad Catz Street Fighter IV FightPad Circuit Board Replacement: 步骤 4 中的图像 1,2 Mad Catz Street Fighter IV FightPad Circuit Board Replacement: 步骤 4 中的图像 2,2
    • Remove the two rubber side grips.
  5. Mad Catz Street Fighter IV FightPad Circuit Board Replacement, RS-DP-LS Switch: 步骤 5 中的图像 1,2 Mad Catz Street Fighter IV FightPad Circuit Board Replacement, RS-DP-LS Switch: 步骤 5 中的图像 2,2
    • Locate RS-DP-LS switch.
    • Pull upwards on the switch to remove it.
  6. Mad Catz Street Fighter IV FightPad Circuit Board Replacement, Circuit Board: 步骤 6 中的图像 1,1
    • Locate the four 8.3 mm Phillips screws on the circuit board and remove them.
  7. Mad Catz Street Fighter IV FightPad Circuit Board Replacement: 步骤 7 中的图像 1,3 Mad Catz Street Fighter IV FightPad Circuit Board Replacement: 步骤 7 中的图像 2,3 Mad Catz Street Fighter IV FightPad Circuit Board Replacement: 步骤 7 中的图像 3,3
    • Hold the controller cable at the area just before it meets the controller and slowly lift upwards to slide it out of its plastic slot and remove the circuit board.
    • Be careful with the wires connected to the circuit board itself as they are thin and delicate.
    • When reassembling the controller, make sure that the bottom plastic piece is fully inserted into its slot before replacing the circuit board.
结论
另外一个人完成了本指南。
Jefferson Hsu
于09/18/12注册
411 声望
创作了3篇指南
团队
Cal Poly, Team 1-7, Propen Fall 2012 Cal Poly, Team 1-7, Propen Fall 2012 的会员
CPSU-PROPEN-F12S1G7
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,043
