跳转到主内容
Mad Catz Street Fighter IV FightPad Buttons Replacement
你所需要的
  1. Mad Catz Street Fighter IV FightPad Buttons Replacement, Rear and Side Case: 步骤 1 中的图像 1,1
    • Use tweezers to completely remove the sticker from the rear of controller.
  2. Mad Catz Street Fighter IV FightPad Buttons Replacement: 步骤 2 中的图像 1,1
    • Find the seven 8.3 mm Phillips screws on the rear of the controller and remove them.
  3. Mad Catz Street Fighter IV FightPad Buttons Replacement: 步骤 3 中的图像 1,2 Mad Catz Street Fighter IV FightPad Buttons Replacement: 步骤 3 中的图像 2,2
    • Use a plastic opening tool to separate the rear and front casing by inserting it in-between the two cases.
    • Use the plastic opening tool to pry the two cases apart.
  4. Mad Catz Street Fighter IV FightPad Buttons Replacement: 步骤 4 中的图像 1,2 Mad Catz Street Fighter IV FightPad Buttons Replacement: 步骤 4 中的图像 2,2
    • Remove the two rubber side grips.
  5. Mad Catz Street Fighter IV FightPad Buttons Replacement, RS-DP-LS Switch: 步骤 5 中的图像 1,2 Mad Catz Street Fighter IV FightPad Buttons Replacement, RS-DP-LS Switch: 步骤 5 中的图像 2,2
    • Locate RS-DP-LS switch.
    • Pull upwards on the switch to remove it.
  6. Mad Catz Street Fighter IV FightPad Buttons Replacement, Circuit Board: 步骤 6 中的图像 1,1
    • Locate the four 8.3 mm Phillips screws on the circuit board and remove them.
  7. Mad Catz Street Fighter IV FightPad Buttons Replacement: 步骤 7 中的图像 1,3 Mad Catz Street Fighter IV FightPad Buttons Replacement: 步骤 7 中的图像 2,3 Mad Catz Street Fighter IV FightPad Buttons Replacement: 步骤 7 中的图像 3,3
    • Hold the controller cable at the area just before it meets the controller and slowly lift upwards to slide it out of its plastic slot and remove the circuit board.
    • Be careful with the wires connected to the circuit board itself as they are thin and delicate.
    • When reassembling the controller, make sure that the bottom plastic piece is fully inserted into its slot before replacing the circuit board.
  8. Mad Catz Street Fighter IV FightPad Buttons Replacement, Buttons: 步骤 8 中的图像 1,2 Mad Catz Street Fighter IV FightPad Buttons Replacement, Buttons: 步骤 8 中的图像 2,2
    • Remove the six buttons one by one by gripping the back of each one and pushing on them from the front.
    • Use tweezers to remove the rubber part of the directional pad before you try to remove the shoulder buttons.
    • When reinserting the buttons make sure they are in the correct place and oriented correctly.
  9. Mad Catz Street Fighter IV FightPad Buttons Replacement: 步骤 9 中的图像 1,1
    • Remove the left and right shoulder buttons by sliding them out of their respective slots.
结论
2等其他人完成本指南。
Eric
于09/26/12注册
117 声望
创作了3篇指南
团队
Cal Poly, Team 1-7, Propen Fall 2012 Cal Poly, Team 1-7, Propen Fall 2012 的会员
CPSU-PROPEN-F12S1G7
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 2,514
