跳转到主内容
Mad Catz Rock Band 4 Wireless Fender 5 Way Toggle Switch Replacement
你所需要的
  1. Mad Catz Rock Band 4 Wireless Fender 5 Way Toggle Switch Replacement, Outer Casing: 步骤 1 中的图像 1,1
    • Flip the guitar over so it is back side up. The battery compartment should be facing up.
    • Use a size J1 head screwdriver to remove the ten 5 mm short screws.
    • Use a J1 screwdriver to remove the four 5 mm long screws on the back of the device.
  2. Mad Catz Rock Band 4 Wireless Fender 5 Way Toggle Switch Replacement: 步骤 2 中的图像 1,1
    • Turn the device over so the front of the guitar is facing you.
    • Using a size J1 philips head screwdriver, remove the eleven 5 mm silver screws (circled in red) around the white panel.
  3. Mad Catz Rock Band 4 Wireless Fender 5 Way Toggle Switch Replacement: 步骤 3 中的图像 1,1
    • Gently lift the white panel and twist 90 degrees clockwise.
    • Using a size J1 head screwdriver, remove the two 5 mm black screws from underneath the white panel. You should now be able to pull the guitar apart.
  4. Mad Catz Rock Band 4 Wireless Fender 5 Way Toggle Switch Replacement, Five Way Toggle Switch: 步骤 4 中的图像 1,1
    • Look for the toggle switch component on the inside of the guitar. The component rests in a black, circular holder that is positioned perpendicular relative to the inside of the front of the guitar.
    • Unscrew the two black, vertical, 5 mm philips head screws holding the part in place using a size J1 screwdriver.
  5. Mad Catz Rock Band 4 Wireless Fender 5 Way Toggle Switch Replacement: 步骤 5 中的图像 1,1
    • Pull the entire component out in a vertical motion.
  6. Mad Catz Rock Band 4 Wireless Fender 5 Way Toggle Switch Replacement: 步骤 6 中的图像 1,1
    • Follow the wires from the component to the main circuit board. Unplug the toggle switch component from the main board.
    • Plug in your replacement toggle switch hardware.
结论
To reassemble your device, follow these instructions in reverse orde
Hollynn Ricker
于09/28/16注册
451 声望
创作了2篇指南
团队
USF Tampa, Team 1-1, Cagle Fall 2016 USF Tampa, Team 1-1, Cagle Fall 2016 的会员
USFT-CAGLE-F16S1G1
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 21
总计 1,255
