跳转到主内容
Mad Catz Dual Force 2 Pro Vibration Motors Replacement
你所需要的
  1. Mad Catz Dual Force 2 Pro Vibration Motors Replacement, Remove Cover: 步骤 1 中的图像 1,1
    • Remove the six 7 mm Phillips screws from the rear cover.
  2. Mad Catz Dual Force 2 Pro Vibration Motors Replacement: 步骤 2 中的图像 1,1
    • Remove the back of the controller.
    • There are no loose items in the controller that can fall out, so you can open it, generally, however you want.
  3. Mad Catz Dual Force 2 Pro Vibration Motors Replacement: 步骤 3 中的图像 1,1
    • Remove the two 7 mm screws on the closest circuit board.
  4. Mad Catz Dual Force 2 Pro Vibration Motors Replacement: 步骤 4 中的图像 1,2 Mad Catz Dual Force 2 Pro Vibration Motors Replacement: 步骤 4 中的图像 2,2
    • Grip the sides of the motor you wish to replace and lift up.
    • Be careful not to tear the wires that connect the motors to the motherboard.
  5. Mad Catz Dual Force 2 Pro Vibration Motors Replacement, Remove the Screw: 步骤 5 中的图像 1,1
    • Use a soldering iron to de-solder both vibration motor wires from the motherboard.
    • If you do not know how to solder, see the soldering guide for instructions.
    • The positive (red) wire connects nearest the edge of the motherboard.
    • When soldering on circuit boards, be sure not to overheat the connection as permanent damage may result.
  6. Mad Catz Dual Force 2 Pro Vibration Motors Replacement: 步骤 6 中的图像 1,1
    • If needed, repeat the last two steps for the other vibration motors.
结论
Alexander Coyne
于01/11/15注册
658 声望
创作了5篇指南
团队
USF Tampa, Team 7-2, Remmell Winter 2015 USF Tampa, Team 7-2, Remmell Winter 2015 的会员
USFT-REMMELL-W15S7G2
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 4
总计 317
