跳转到主内容
Mad Catz Dual Force 2 Pro Motherboard Replacement
你所需要的
  1. Mad Catz Dual Force 2 Pro Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Remove the six 7 mm Phillips screws from the rear cover.
  2. Mad Catz Dual Force 2 Pro Motherboard Replacement: 步骤 2 中的图像 1,1
    • Remove the back of the controller.
    • There are no loose items in the controller that can fall out, so you can open it, generally, however you want.
  3. Mad Catz Dual Force 2 Pro Motherboard Replacement: 步骤 3 中的图像 1,1
    • Remove the two 7 mm screws on the closest circuit board.
  4. Mad Catz Dual Force 2 Pro Motherboard Replacement: 步骤 4 中的图像 1,2 Mad Catz Dual Force 2 Pro Motherboard Replacement: 步骤 4 中的图像 2,2
    • Lift the closest circuit board away from the motherboard.
    • Be sure you do not tear the ribbon connecting the smaller circuit board to the motherboard.
  5. Mad Catz Dual Force 2 Pro Motherboard Replacement: 步骤 5 中的图像 1,1
    • Remove the two 7 mm Philip screws on the motherboard.
  6. Mad Catz Dual Force 2 Pro Motherboard Replacement: 步骤 6 中的图像 1,1
    • Remove the motherboard assembly from the cover.
结论
另外一个人完成了本指南。
Alexander Coyne
于01/11/15注册
658 声望
创作了5篇指南
团队
USF Tampa, Team 7-2, Remmell Winter 2015 USF Tampa, Team 7-2, Remmell Winter 2015 的会员
USFT-REMMELL-W15S7G2
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 582
