当前版本的文档还未经巡查,您可以查看最新的已查核版本。
To insert the battery, gently slide it into the compartment until it clicks in place.
To remove, slide the button highlighted in the red rectangle to the right to release the battery and slide it from the compartment.
With a Torx #9 screwdriver, remove the two .20 in. screws circled in red that are holding the trackpad in place.
Then disconnect the ribbon highlighted with the red rectangle connecting the trackpad to the laptop.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
