当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
The battery compartment is located in the front-right side of the laptop.
To insert the battery, gently slide it into the compartment until it clicks in place.
To remove, slide the button highlighted in the red rectangle to the right to release the battery and slide it from the compartment.
With the laptop upside down and with the battery removed, use a Torx #9 screw driver to remove the three .84 in. screws shown.
Carefully pull up on the front of the keyboard to pop it out from the case.
Then slide the back out so the keyboard becomes nearly free.
Disconnect the ribbon that is connecting the keyboard to the rest of the computer.
Pull the keyboard out and repair or replace as needed.
Remove the RAM board located underneath the keyboard by carefully popping it out from its connection. Reinstall or replace as necessary.
取消:我没有完成这个指南。
与6其他贡献者
于10/10/11注册
63 声望
创作了4篇指南
徽章: 5
+ 2更多徽章
CPSU-REGAN-F11S6G1
4 名成员
创作了6篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 18
总计 930
