跳转到主内容
Macintosh Powerbook 5300cs Keyboard Replacement
你所需要的
  1. Macintosh Powerbook 5300cs Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • The battery compartment is located in the front-right side of the laptop.
  2. Macintosh Powerbook 5300cs Keyboard Replacement: 步骤 2 中的图像 1,1
    • To insert the battery, gently slide it into the compartment until it clicks in place.
    • To remove, slide the button highlighted in the red rectangle to the right to release the battery and slide it from the compartment.
  3. Macintosh Powerbook 5300cs Keyboard Replacement, Keyboard: 步骤 3 中的图像 1,1
    • With the laptop upside down and with the battery removed, use a Torx #9 screw driver to remove the three .84 in. screws shown.
  4. Macintosh Powerbook 5300cs Keyboard Replacement: 步骤 4 中的图像 1,2 Macintosh Powerbook 5300cs Keyboard Replacement: 步骤 4 中的图像 2,2
    • Carefully pull up on the front of the keyboard to pop it out from the case.
    • Then slide the back out so the keyboard becomes nearly free.
  5. Macintosh Powerbook 5300cs Keyboard Replacement: 步骤 5 中的图像 1,3 Macintosh Powerbook 5300cs Keyboard Replacement: 步骤 5 中的图像 2,3 Macintosh Powerbook 5300cs Keyboard Replacement: 步骤 5 中的图像 3,3
    • Disconnect the ribbon that is connecting the keyboard to the rest of the computer.
    • Pull the keyboard out and repair or replace as needed.
结论
另外一个人完成了本指南。
Ronan
于10/10/11注册
72 声望
创作了4篇指南
团队
Cal Poly, Team 6-1, Regan Fall 2011 Cal Poly, Team 6-1, Regan Fall 2011 的会员
CPSU-REGAN-F11S6G1
4 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 895
