跳转到主内容
Macintosh Powerbook 5300cs Battery Replacement
你所需要的
  1. Macintosh Powerbook 5300cs Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • The battery compartment is located in the front-right side of the laptop.
  2. Macintosh Powerbook 5300cs Battery Replacement: 步骤 2 中的图像 1,1
    • To insert the battery, gently slide it into the compartment until it clicks in place.
    • To remove, slide the button highlighted in the red rectangle to the right to release the battery and slide it from the compartment.
    This is not to remove the battery, this is to remove the expansion slot (which has got the floppy disk module in it, in the first picture.
    blrutter - 回复
    Sorry I should have mentioned it in my prior comment. The battery has got a release button on it too, but it’s part of the battery, exposed on the front face of the right front corner when the battery is installed.
    blrutter - 回复
结论
2等其他人完成本指南。
noah fischer
于10/10/11注册
222 声望
撰写一个指南
团队
Cal Poly, Team 6-1, Regan Fall 2011 Cal Poly, Team 6-1, Regan Fall 2011 的会员
CPSU-REGAN-F11S6G1
4 名成员
创作了6篇指南
一条评论
What’s the part number of the battery?
applerepairshop - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 1,531
