跳转到主内容
加入维修社区 - 创建账户
Macintosh PowerBook 165c Hard Drive Replacement
你所需要的
  1. Macintosh PowerBook 165c Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Orient the computer so the battery is facing you.
    • Slide the gray plastic battery cover to the right.
    询问修复机器人
  2. Macintosh PowerBook 165c Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Pull the battery toward yourself until it is fully detached.
    询问修复机器人
  3. Macintosh PowerBook 165c Hard Drive Replacement, Input/Output Door: 步骤 3 中的图像 1,1
    • Orient the computer right side up with the rear facing you.
    • Open the Input/Output (I/O) door.
    询问修复机器人
  4. Macintosh PowerBook 165c Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Carefully bend the door into an arch until one of the pins releases from its slot.
    • Once one of the pins is free, remove the I/O door from the computer.
    询问修复机器人
  5. Macintosh PowerBook 165c Hard Drive Replacement, Lower Case: 步骤 5 中的图像 1,1
    • Orient the computer with the bottom facing up and rear facing you. You should be able to read the Macintosh label in this position.
    询问修复机器人
  6. Macintosh PowerBook 165c Hard Drive Replacement: 步骤 6 中的图像 1,1
    • Use a T8 torx screwdriver to remove the 6.8mm long screw above and to the right of the modem jack.
    • Twist counter clockwise to remove the screw.
    询问修复机器人
  7. Macintosh PowerBook 165c Hard Drive Replacement: 步骤 7 中的图像 1,1
    • Use a T10 torx screwdriver to remove the four, 18mm long screws from the lower case.
    询问修复机器人
  8. Macintosh PowerBook 165c Hard Drive Replacement: 步骤 8 中的图像 1,2 Macintosh PowerBook 165c Hard Drive Replacement: 步骤 8 中的图像 2,2
    • Place your hands on the lower case, just above the I/O panel, and slowly lift the lower case a few inches above the main body of the computer.
    • Release the large, gray interconnect ribbon cable just behind the I/O panel.
    • Caution: Lower case cannot be fully removed until two plastic clips in the front corners are released. See the following step for details.
    询问修复机器人
  9. Macintosh PowerBook 165c Hard Drive Replacement: 步骤 9 中的图像 1,2 Macintosh PowerBook 165c Hard Drive Replacement: 步骤 9 中的图像 2,2
    • Place your thumb on the upper case, inside the empty battery slot, and your index finger near your thumb on the left side of the lower case.
    • Pinch your thumb and index finger towards each other to release the clip. Without releasing pressure on the pinch grip, use your index finger to push the lower case upwards.
    • Lift the lower case to remove it.
    询问修复机器人
  10. Macintosh PowerBook 165c Hard Drive Replacement, Modem Card: 步骤 10 中的图像 1,1
    • Orient the computer so the ports are facing you.
    询问修复机器人
  11. Macintosh PowerBook 165c Hard Drive Replacement: 步骤 11 中的图像 1,2 Macintosh PowerBook 165c Hard Drive Replacement: 步骤 11 中的图像 2,2
    • Locate the Modem Card on the lower case.
    • Use a T8 torx screwdriver to remove the two, 7.7mm long screws from the two corners.
    • The modem card is an optional component on the Macintosh 165c, and may not be included in all devices.
    询问修复机器人
  12. Macintosh PowerBook 165c Hard Drive Replacement: 步骤 12 中的图像 1,1
    • Lift the modem card directly upward until it releases from the connector.
    • If the modem card is difficult to remove, gently jostle it back and forth as you lift up.
    询问修复机器人
  13. Macintosh PowerBook 165c Hard Drive Replacement, RAM and PSRAM Expansion Card: 步骤 13 中的图像 1,2 Macintosh PowerBook 165c Hard Drive Replacement, RAM and PSRAM Expansion Card: 步骤 13 中的图像 2,2
    • Locate and lift ram card directly up until connector releases.
    • Move the card back and forth gently if the connector does not release immediately.
    询问修复机器人
  14. Macintosh PowerBook 165c Hard Drive Replacement: 步骤 14 中的图像 1,2 Macintosh PowerBook 165c Hard Drive Replacement: 步骤 14 中的图像 2,2
    • Locate and lift the PSRAM expansion card vertically until connector releases.
    • If the PSRAM expansion card is difficult to remove, gently jostle it back and forth as you lift up.
    • The PSRAM expansion card is an optional component, and may not be included in all devices.
    询问修复机器人
  15. Macintosh PowerBook 165c Hard Drive Replacement, Daughterboard: 步骤 15 中的图像 1,1
    • Use T8 torx screwdriver to remove four, 7.7mm long screws from the perimeter of the daughterboard.
    询问修复机器人
  16. Macintosh PowerBook 165c Hard Drive Replacement: 步骤 16 中的图像 1,1
    • Life the daughterboard directly up to remove it from the connector.
    • If the daughterboard does not easily release from the connector, gently jostle it back and forth as you lift up.
    询问修复机器人
  17. Macintosh PowerBook 165c Hard Drive Replacement, Hard Drive: 步骤 17 中的图像 1,1
    • Use a T8 torx screwdriver to remove the five, 6.8mm long screws on the drive retainer.
    询问修复机器人
  18. Macintosh PowerBook 165c Hard Drive Replacement: 步骤 18 中的图像 1,3 Macintosh PowerBook 165c Hard Drive Replacement: 步骤 18 中的图像 2,3 Macintosh PowerBook 165c Hard Drive Replacement: 步骤 18 中的图像 3,3
    • Orient the computer so the plastic clip in top left corner of the lower case is facing you. Release the clip by lifting the retainer. You may need to adjust the position of the hard drive to remove the retainer.
    • Lift the drive retainer out.
    询问修复机器人
  19. Macintosh PowerBook 165c Hard Drive Replacement: 步骤 19 中的图像 1,1
    • Pull the orange connector attached to the ribbon cable until the connector releases from the motherboard.
    询问修复机器人
  20. Macintosh PowerBook 165c Hard Drive Replacement: 步骤 20 中的图像 1,1
    • Lift the hard drive to remove it.
    询问修复机器人
结论
2等其他人完成本指南。
John
于10/12/11注册
88 声望
创作了4篇指南
团队
Cal Poly, Team 6-3, Regan Fall 2011 Cal Poly, Team 6-3, Regan Fall 2011 的会员
CPSU-REGAN-F11S6G3
4 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 14
过去 30 天: 96
总计 4,151
