当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Turn the device upside down and then locate the battery latch near the front of the device.
Slide the latch to the left to release the battery.
Continue holding the latch then gently pull the battery out of the device.
Place the battery in a safe location.
Locate the CD-ROM Drive latch.
Slide the latch to the right to release the CD ROM drive.
Continue holding the latch then gently pull the CD-ROM Drive out of the device.
Place the CD ROM drive in a safe location.
Locate the speaker cover.
Press firmly on each end of the speaker cover and slide it to the left.
Gently lift the speaker cover to remove it.
Lift the keyboard up from the back using a spudger(wedge side).
Gently lift the keyboard until only the ribbon cable remains attached.
Tilt the keyboard away from the screen.
Locate the six screws that secure the heatsink.
Remove the six screws from the heatsink using the Philips #1 screwdriver.
Lift the heatsink from the side closest to the laptop screen.
Remove the heatsink.
Gently pull up on the beige ribbon lock until it moves a short distance on both sides to separate the ribbon cable from the connector.
Detach the ribbon cable.
Remove the keyboard.
取消:我没有完成这个指南。
另外一个人完成了本指南。
与12其他贡献者
于04/01/11注册
41 声望
撰写一个指南
徽章: 4
+1个徽章
CPSU-FORTE-S11S10G39
5 名成员
创作了6篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 25
总计 2,439
