跳转到主内容
加入维修社区 - 创建账户
Macintosh PowerBook 1400 Series Keyboard Replacement
你所需要的
  1. Macintosh PowerBook 1400 Series Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the device upside down and then locate the battery latch near the front of the device.
  2. Macintosh PowerBook 1400 Series Keyboard Replacement: 步骤 2 中的图像 1,1
    • Slide the latch to the left to release the battery.
  3. Macintosh PowerBook 1400 Series Keyboard Replacement: 步骤 3 中的图像 1,1
    • Continue holding the latch then gently pull the battery out of the device.
    • Place the battery in a safe location.
  4. Macintosh PowerBook 1400 Series Keyboard Replacement, CD-ROM Drive: 步骤 4 中的图像 1,1
    • Locate the CD-ROM Drive latch.
  5. Macintosh PowerBook 1400 Series Keyboard Replacement: 步骤 5 中的图像 1,1
    • Slide the latch to the right to release the CD ROM drive.
  6. Macintosh PowerBook 1400 Series Keyboard Replacement: 步骤 6 中的图像 1,1
    • Continue holding the latch then gently pull the CD-ROM Drive out of the device.
    • Place the CD ROM drive in a safe location.
  7. Macintosh PowerBook 1400 Series Keyboard Replacement, Keyboard: 步骤 7 中的图像 1,1
    • Locate the speaker cover.
  8. Macintosh PowerBook 1400 Series Keyboard Replacement: 步骤 8 中的图像 1,1
    • Press firmly on each end of the speaker cover and slide it to the left.
  9. Macintosh PowerBook 1400 Series Keyboard Replacement: 步骤 9 中的图像 1,1
    • Gently lift the speaker cover to remove it.
  10. Macintosh PowerBook 1400 Series Keyboard Replacement: 步骤 10 中的图像 1,1
    • Lift the keyboard up from the back using a spudger(wedge side).
  11. Macintosh PowerBook 1400 Series Keyboard Replacement: 步骤 11 中的图像 1,1
    • Gently lift the keyboard until only the ribbon cable remains attached.
  12. Macintosh PowerBook 1400 Series Keyboard Replacement: 步骤 12 中的图像 1,1
    • Tilt the keyboard away from the screen.
  13. Macintosh PowerBook 1400 Series Keyboard Replacement: 步骤 13 中的图像 1,1
    • Locate the six screws that secure the heatsink.
  14. Macintosh PowerBook 1400 Series Keyboard Replacement: 步骤 14 中的图像 1,1
    • Remove the six screws from the heatsink using the Philips #1 screwdriver.
  15. Macintosh PowerBook 1400 Series Keyboard Replacement: 步骤 15 中的图像 1,1
    • Lift the heatsink from the side closest to the laptop screen.
  16. Macintosh PowerBook 1400 Series Keyboard Replacement: 步骤 16 中的图像 1,1
    • Remove the heatsink.
  17. Macintosh PowerBook 1400 Series Keyboard Replacement: 步骤 17 中的图像 1,1
    • Gently pull up on the beige ribbon lock until it moves a short distance on both sides to separate the ribbon cable from the connector.
  18. Macintosh PowerBook 1400 Series Keyboard Replacement: 步骤 18 中的图像 1,1
    • Detach the ribbon cable.
  19. Macintosh PowerBook 1400 Series Keyboard Replacement: 步骤 19 中的图像 1,1
    • Remove the keyboard.
结论
另外一个人完成了本指南。
Sean Bent
于04/01/11注册
41 声望
撰写一个指南
团队
Cal Poly, Team 10-39, Forte Spring 2011 Cal Poly, Team 10-39, Forte Spring 2011 的会员
CPSU-FORTE-S11S10G39
5 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 33
总计 2,800
