跳转到主内容
加入维修社区 - 创建账户
Macintosh PowerBook 1400 Series Hard Drive Replacement
你所需要的
  1. Macintosh PowerBook 1400 Series Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the device upside down and then locate the battery latch near the front of the device.
  2. Macintosh PowerBook 1400 Series Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Slide the latch to the left to release the battery.
  3. Macintosh PowerBook 1400 Series Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Continue holding the latch then gently pull the battery out of the device.
    • Place the battery in a safe location.
  4. Macintosh PowerBook 1400 Series Hard Drive Replacement, CD-ROM Drive: 步骤 4 中的图像 1,1
    • Locate the CD-ROM Drive latch.
  5. Macintosh PowerBook 1400 Series Hard Drive Replacement: 步骤 5 中的图像 1,1
    • Slide the latch to the right to release the CD ROM drive.
  6. Macintosh PowerBook 1400 Series Hard Drive Replacement: 步骤 6 中的图像 1,1
    • Continue holding the latch then gently pull the CD-ROM Drive out of the device.
    • Place the CD ROM drive in a safe location.
  7. Macintosh PowerBook 1400 Series Hard Drive Replacement, Keyboard: 步骤 7 中的图像 1,1
    • Locate the speaker cover.
  8. Macintosh PowerBook 1400 Series Hard Drive Replacement: 步骤 8 中的图像 1,1
    • Press firmly on each end of the speaker cover and slide it to the left.
  9. Macintosh PowerBook 1400 Series Hard Drive Replacement: 步骤 9 中的图像 1,1
    • Gently lift the speaker cover to remove it.
  10. Macintosh PowerBook 1400 Series Hard Drive Replacement: 步骤 10 中的图像 1,1
    • Lift the keyboard up from the back using a spudger(wedge side).
  11. Macintosh PowerBook 1400 Series Hard Drive Replacement: 步骤 11 中的图像 1,1
    • Gently lift the keyboard until only the ribbon cable remains attached.
  12. Macintosh PowerBook 1400 Series Hard Drive Replacement: 步骤 12 中的图像 1,1
    • Tilt the keyboard away from the screen.
  13. Macintosh PowerBook 1400 Series Hard Drive Replacement: 步骤 13 中的图像 1,1
    • Locate the six screws that secure the heatsink.
  14. Macintosh PowerBook 1400 Series Hard Drive Replacement: 步骤 14 中的图像 1,1
    • Remove the six screws from the heatsink using the Philips #1 screwdriver.
  15. Macintosh PowerBook 1400 Series Hard Drive Replacement: 步骤 15 中的图像 1,1
    • Lift the heatsink from the side closest to the laptop screen.
  16. Macintosh PowerBook 1400 Series Hard Drive Replacement: 步骤 16 中的图像 1,1
    • Remove the heatsink.
  17. Macintosh PowerBook 1400 Series Hard Drive Replacement: 步骤 17 中的图像 1,1
    • Gently pull up on the beige ribbon lock until it moves a short distance on both sides to separate the ribbon cable from the connector.
  18. Macintosh PowerBook 1400 Series Hard Drive Replacement: 步骤 18 中的图像 1,1
    • Detach the ribbon cable.
  19. Macintosh PowerBook 1400 Series Hard Drive Replacement: 步骤 19 中的图像 1,1
    • Remove the keyboard.
  20. Macintosh PowerBook 1400 Series Hard Drive Replacement, Hard Drive: 步骤 20 中的图像 1,1
    • Locate and identify the two screws that attach the hard drive to the computer.
  21. Macintosh PowerBook 1400 Series Hard Drive Replacement: 步骤 21 中的图像 1,1
    • Remove the screws with a Phillips #0 screwdriver.
  22. Macintosh PowerBook 1400 Series Hard Drive Replacement: 步骤 22 中的图像 1,1
    • Once the screws are removed, lift up the end of the hard drive using your finger tips.
  23. Macintosh PowerBook 1400 Series Hard Drive Replacement: 步骤 23 中的图像 1,1
    • Fully lift the hard drive vertically against the side of the computer.
  24. Macintosh PowerBook 1400 Series Hard Drive Replacement: 步骤 24 中的图像 1,1
    • Push a finger down onto the plastic strap.
  25. Macintosh PowerBook 1400 Series Hard Drive Replacement: 步骤 25 中的图像 1,1
    • Remove the hard drive from the computer by pushing down on the plastic strap and pulling up on the hard drive.
结论
11等其他人完成本指南。
团队
Cal Poly, Team 10-39, Forte Spring 2011 Cal Poly, Team 10-39, Forte Spring 2011 的会员
CPSU-FORTE-S11S10G39
5 名成员
创作了6篇指南
1指南评论
Hi iFixIt thanks for all the details BUT the keyboard can indeed stay in
when changing the hard drive. Just slide it a bit to the right after step
11, the ribbon cble does not take any damage. SO: from step 12 jump
straight to step 20. The heat sink can stay untouched, which i find not
unimportant to mention. Regards, TB75
TB75 - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 16
过去 30 天: 44
总计 9,838
