跳转到主内容
Macintosh IIsi Ram Replacement
你所需要的
  1. Macintosh IIsi Ram Replacement, Top Case: 步骤 1 中的图像 1,2 Macintosh IIsi Ram Replacement, Top Case: 步骤 1 中的图像 2,2
    • Start by turning the computer around, and remove this #0 Phillips Screw.
    • There may or may not be a Phillips #0 screw here, depending on whether or not the computer has ever been serviced.
  2. Macintosh IIsi Ram Replacement: 步骤 2 中的图像 1,3 Macintosh IIsi Ram Replacement: 步骤 2 中的图像 2,3 Macintosh IIsi Ram Replacement: 步骤 2 中的图像 3,3
    • Now lift these two clips, and slowly pivot the case up.
    • You can now seperate the top of the computer from the rest of the machine.
  3. Macintosh IIsi Ram Replacement, Ram: 步骤 3 中的图像 1,3 Macintosh IIsi Ram Replacement, Ram: 步骤 3 中的图像 2,3 Macintosh IIsi Ram Replacement, Ram: 步骤 3 中的图像 3,3
    • The IIsi uses 4 30-Pin SIMMs (Installed in pairs of 2) for a maximum ram capacity of 65MB. It has 1MB soldered to the logic board as well.
    • Start with this SIMM. Push these 2 metal tabs outward, then push the ram forward. It can then be lifted out. You have to remove the SIMMs in order, starting with the one you just removed. You can then work your way through all of them.
  4. Macintosh IIsi Ram Replacement: 步骤 4 中的图像 1,3 Macintosh IIsi Ram Replacement: 步骤 4 中的图像 2,3 Macintosh IIsi Ram Replacement: 步骤 4 中的图像 3,3
    • 1st Photo: The RAM Module
结论
4等其他人完成本指南。
Chris Green
于10/11/09注册
37,197 声望
创作了49篇指南
团队
Master Techs Master Techs 的会员
Community
321 名成员
创作了1,525篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 13
总计 2,248
