跳转到主内容
Macintosh IIsi Hard Drive Replacement
你所需要的
  1. Macintosh IIsi Hard Drive Replacement, Top Case: 步骤 1 中的图像 1,2 Macintosh IIsi Hard Drive Replacement, Top Case: 步骤 1 中的图像 2,2
    • Start by turning the computer around, and remove this #0 Phillips Screw.
    • There may or may not be a Phillips #0 screw here, depending on whether or not the computer has ever been serviced.
  2. Macintosh IIsi Hard Drive Replacement: 步骤 2 中的图像 1,3 Macintosh IIsi Hard Drive Replacement: 步骤 2 中的图像 2,3 Macintosh IIsi Hard Drive Replacement: 步骤 2 中的图像 3,3
    • Now lift these two clips, and slowly pivot the case up.
    • You can now seperate the top of the computer from the rest of the machine.
  3. Macintosh IIsi Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 1,3 Macintosh IIsi Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 2,3 Macintosh IIsi Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 3,3
    • The Macintosh IIsi's hard drive is located ajacent to the ram and floppy drive.
    • Start by pushing these two tabs out, and lifting the drive up.
    • Then, flip the drive over, and remove the connection cables.
  4. Macintosh IIsi Hard Drive Replacement: 步骤 4 中的图像 1,3 Macintosh IIsi Hard Drive Replacement: 步骤 4 中的图像 2,3 Macintosh IIsi Hard Drive Replacement: 步骤 4 中的图像 3,3
    • The hard drive: A Quantum ProDrive LPS, made in 1990, and surprisingly, it still works!
    • This drive has an 80MB capacity, not very large by today's standards, but not bad way back then...
    • Believe it or not, hard drive construction hasn't changed much in the last 20 years. Other than a few new interfaces, the form factor, 3.5" width and 4-Pin 12V/5V power connector has stayed the same.
结论
4等其他人完成本指南。
Chris Green
于10/11/09注册
37,197 声望
创作了49篇指南
团队
Master Techs Master Techs 的会员
Community
321 名成员
创作了1,516篇指南
2条评论
Hello cano you please tell me how is the jumpering setting for a Quantum Prodrive LT 700MB
Juan - 回复
Is there a way to read the HDD on a PC?
Charles - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 3,980
