跳转到主内容
MacBook Unibody Model A1342 Optical Drive Replacement
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. MacBook Unibody Model A1342 Optical Drive Replacement, Optical Drive: 步骤 1 中的图像 1,1
    • Remove the single 12 mm Phillips screw securing the top of the rear speaker housing to the upper case.
  2. MacBook Unibody Model A1342 Optical Drive Replacement: 步骤 2 中的图像 1,1
    • Remove the single 2.2 mm Phillips screw inserted horizontally into the side of the optical drive.
    • This screw is located in a gap within the right speaker assembly, and is visible only from the hinge edge.
  3. MacBook Unibody Model A1342 Optical Drive Replacement: 步骤 3 中的图像 1,1
    • Use the flat end of a spudger to pry the AirPort/Bluetooth ribbon cable connector up off the logic board.
  4. MacBook Unibody Model A1342 Optical Drive Replacement: 步骤 4 中的图像 1,1
    • Use the flat end of a spudger to pry the rear speaker connector up off the logic board.
    • Pry up underneath the wires.
    • This connector is very delicate and easily broken.
  5. MacBook Unibody Model A1342 Optical Drive Replacement: 步骤 5 中的图像 1,1
    • Carefully rotate the rear speaker assembly (with AirPort/Antenna cables still attached) out of the lower case.
  6. MacBook Unibody Model A1342 Optical Drive Replacement: 步骤 6 中的图像 1,1
    • Use the flat end of a spudger to pry the optical drive connector up off the logic board.
  7. MacBook Unibody Model A1342 Optical Drive Replacement: 步骤 7 中的图像 1,1
    • Remove the single 4.5 mm Phillips screw securing the optical drive bracket to the upper case near the fan.
  8. MacBook Unibody Model A1342 Optical Drive Replacement: 步骤 8 中的图像 1,1
    • Remove the two 2.5 mm Phillips screws securing the optical drive to the upper case near the optical drive opening.
  9. MacBook Unibody Model A1342 Optical Drive Replacement: 步骤 9 中的图像 1,1
    • Lift the optical drive near its connector and pull it away from the upper case to remove it from the computer.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 12
总计 813
