跳转到主内容
MacBook Unibody Model A1342 Lower Case Replacement
你所需要的
  1. MacBook Unibody Model A1342 Lower Case Replacement, Lower Case: 步骤 1 中的图像 1,1
    • Remove the eight 4 mm Phillips screws securing the lower case to the MacBook.
  2. MacBook Unibody Model A1342 Lower Case Replacement: 步骤 2 中的图像 1,3 MacBook Unibody Model A1342 Lower Case Replacement: 步骤 2 中的图像 2,3 MacBook Unibody Model A1342 Lower Case Replacement: 步骤 2 中的图像 3,3
    • The lower case is constructed of rubber-coated aluminum. Do not excessively bend the aluminum during removal, as any permanent deformation will cause tolerance issues after reassembly.
    • Slightly lift the lower case near the vent opening.
    • Continue running your fingers between the lower and upper cases until the upper case pops off its retaining clips.
    • The location of these three clips is shown in the third picture.
结论
74等其他人完成本指南。
2条评论
Apple has a recall on this part, so you can get a replacement for an improved version free and save yourself $149.99. Check out http://www.apple.com/support/macbook-bot...
Shane - 回复
Would the Macbook Pro back cover also fit this?
wow - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 37
总计 69,699
