跳转到主内容
MacBook Unibody Model A1342 LCD Replacement
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. MacBook Unibody Model A1342 LCD Replacement, LCD: 步骤 1 中的图像 1,1
    • Remove following six screws securing the LCD to the rear display bezel:
    • Four 3.4 mm Phillips.
    • Two 3 mm Phillips.
  2. MacBook Unibody Model A1342 LCD Replacement: 步骤 2 中的图像 1,1
    • Do not try to remove the LCD yet. The circuitry along its lower edge is wedged in a gap along the lower edge of the display recess in the plastic display assembly.
    • Hold the display vertically and tip it enough to grab the top edge of the LCD and rotate it slightly out of the display assembly, being careful not to break the circuitry off its lower edge.
  3. MacBook Unibody Model A1342 LCD Replacement: 步骤 3 中的图像 1,1
    • Peel the piece of tape covering the display data cable connector away from the edge closest to the LCD.
  4. MacBook Unibody Model A1342 LCD Replacement: 步骤 4 中的图像 1,2 MacBook Unibody Model A1342 LCD Replacement: 步骤 4 中的图像 2,2
    • Use the tip of a spudger to flip up the thin steel retaining clip securing the display data cable to its socket on the LCD.
    • Pull the display data cable straight away from its socket on the LCD.
    • Lift the LCD out of the display assembly and set it aside.
结论
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 862
