本指南有最近更改,您可查看未经巡查的最新版本。
简介
This guide will show you how to replace the hard drive cable.
你所需要的
Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
Remove two 11 mm Phillips screws securing the hard drive bracket to the upper case.
Remove the 3.1 mm Phillips screw securing the hard drive cable to the upper case.
即将完成!
结论
19等其他人完成本指南。
