本指南有最近更改,您可查看未经巡查的最新版本。
简介
Faulty Wi-Fi or Bluetooth connection? Replace the AirPort/Bluetooth cable.
你所需要的
Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
Use the flat end of a spudger to pry the AirPort/Bluetooth cable connector up off the logic board.
Carefully peel the AirPort/Bluetooth ribbon cable from its channel within the rear speaker assembly.
10等其他人完成本指南。
