本指南有最近更改,您可查看未经巡查的最新版本。
简介
This guide will show you how to replace the SuperDrive from your laptop (requires a SATA SuperDrive).
你所需要的
With the case closed, place the Unibody top-side down on a flat surface.
Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
Remove the following eight screws securing the lower case to the chassis:
One 3 mm Phillips screw.
Three 13.5 mm Phillips screws.
Four 3.5 mm Phillips screws.
Using the flat end of a spudger, pry the subwoofer connector straight up off the logic board.
Remove the optical drive cable by pulling it straight away from the optical drive.
Remove the two black Phillips #0 screws securing the small metal mounting bracket. Transfer this bracket to your new optical drive or hard drive enclosure.
108等其他人完成本指南。
8条评论
I ruined my laptop because of this guide.
The step 6 says it's a connector that comes of (sub-woofer), mine was welded, I broke it, I cannot fix it.
i am frustrated, and I know I should only blame myself for following blindly that guide.
But at least I thought I should let people know : be careful when removing that sub-woofer connector!!!
I also broke the sub-woofer connector away from the board, the connection to the board is very fragile, however I managed to solder the connector back on with a very fine soldering iron, (tricky). but it worked. I don't think it is really necessary to disconnect the sub-woofer cable to remove the optical drive, I'll find out when I get a new one to replace the old broken one. To remove the subwoofer cable it would be necessary to hold the connector in place while the plug is very carefully prized up from the lead side without moving the connector socket.
Completed this one successfully. Now running OCZ 256 GB SSD in main bay and WD Black 320GB in optical bay.
My computer had a different optical drive than shown. Instead of the screws going through the body of the drive, it was secured by two screws at the corners opposite the screw by the connectors (i.e, along the wall where the CD slot is). In addition, in order to repair the drive, black tape sealing the unit had to be peeled back in order to open it (and the screws underneath the tape were placed slightly differently).
