本指南有最近更改,您可查看未经巡查的最新版本。
简介
Replacing the hard drive on a Unibody is simple - it only requires removing one screw!
你所需要的
With the case closed, place the Unibody top-side down on a flat surface.
Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
Remove the single Phillips screw securing the hard drive bracket to the upper case.
即将完成!
结论
