跳转到主内容
MacBook Unibody Model A1278 DC-In Board Replacement
你所需要的
  1. MacBook Unibody Model A1278 DC-In Board Replacement, Access Door: 步骤 1 中的图像 1,1
    • With the case closed, place the Unibody top-side down on a flat surface.
    • Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
  2. MacBook Unibody Model A1278 DC-In Board Replacement: 步骤 2 中的图像 1,1
    • The access door should now be raised enough to lift it up and out of the Unibody.
  3. MacBook Unibody Model A1278 DC-In Board Replacement, Battery: 步骤 3 中的图像 1,1
    • Be sure the access door release latch is vertical before proceeding.
    • Grab the white plastic tab and pull the battery up and out of the Unibody.
  4. MacBook Unibody Model A1278 DC-In Board Replacement, Lower Case: 步骤 4 中的图像 1,1
    • Remove the following eight screws securing the lower case to the chassis:
    • One 3 mm Phillips screw.
    • Four 3.5 mm Phillips screws.
  5. MacBook Unibody Model A1278 DC-In Board Replacement: 步骤 5 中的图像 1,1
    • Using both hands, lift and remove the lower case off the upper case.
  6. MacBook Unibody Model A1278 DC-In Board Replacement, Mid Wall: 步骤 6 中的图像 1,1
    • Remove the four 10.3 mm Phillips screws securing the mid wall to the upper case.
  7. MacBook Unibody Model A1278 DC-In Board Replacement: 步骤 7 中的图像 1,1
    • Lift the mid wall out of the upper case.
  8. MacBook Unibody Model A1278 DC-In Board Replacement, Fan: 步骤 8 中的图像 1,3 MacBook Unibody Model A1278 DC-In Board Replacement, Fan: 步骤 8 中的图像 2,3 MacBook Unibody Model A1278 DC-In Board Replacement, Fan: 步骤 8 中的图像 3,3
    • Use a spudger to pry the fan connector straight up off the logic board.
    • It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
    • The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket. The layout of the logic board shown in the second picture may look slightly different than your machine but the fan socket is the same.
  9. MacBook Unibody Model A1278 DC-In Board Replacement: 步骤 9 中的图像 1,1
    • Remove the following three screws securing the fan to the upper case:
    • Two 5 mm Phillips screws.
    • One 7 mm Phillips screw.
    • The longer of the three screws belongs in the upper left corner of the fan.
  10. MacBook Unibody Model A1278 DC-In Board Replacement: 步骤 10 中的图像 1,1
    • Lift the fan out of the upper case.
  11. MacBook Unibody Model A1278 DC-In Board Replacement, Logic Board: 步骤 11 中的图像 1,1
    • In the next few steps, you will disconnect the highlighted cables which connect the logic board to the upper case.
    • Each connector is different, so the following steps will show you how disconnect each in detail.
  12. MacBook Unibody Model A1278 DC-In Board Replacement: 步骤 12 中的图像 1,2 MacBook Unibody Model A1278 DC-In Board Replacement: 步骤 12 中的图像 2,2
    • Remove the single Phillips screw securing the battery cable cover to the upper case.
    • Remove the battery cable cover from the upper case.
  13. MacBook Unibody Model A1278 DC-In Board Replacement: 步骤 13 中的图像 1,1
    • Use a spudger to pry the battery level indicator cable connector straight up off the logic board.
  14. MacBook Unibody Model A1278 DC-In Board Replacement: 步骤 14 中的图像 1,1
    在这个步骤中使用的工具:
    • Disconnect the battery cable connector by pulling it straight away from the logic board.
    • If you cannot grasp the cable with your fingers, a spudger and tweezers may be helpful for removal.
  15. MacBook Unibody Model A1278 DC-In Board Replacement: 步骤 15 中的图像 1,3 MacBook Unibody Model A1278 DC-In Board Replacement: 步骤 15 中的图像 2,3 MacBook Unibody Model A1278 DC-In Board Replacement: 步骤 15 中的图像 3,3
    • Using the tip of a spudger, flip up the keyboard ribbon cable retaining flap.
    • Pull the keyboard ribbon cable straight out of its socket.
    • If the smaller connector at the right side of the keyboard ribbon cable is populated by another small black ribbon cable, remove it in a similar way to the above.
  16. MacBook Unibody Model A1278 DC-In Board Replacement: 步骤 16 中的图像 1,1
    • Use the flat end of a spudger to pry the trackpad connector straight up off the logic board.
  17. MacBook Unibody Model A1278 DC-In Board Replacement: 步骤 17 中的图像 1,2 MacBook Unibody Model A1278 DC-In Board Replacement: 步骤 17 中的图像 2,2
    • Use the tip of a spudger to flip up the locking lever to release the IR sensor ribbon cable from its socket.
    • Use the tip of a spudger to pull the IR sensor ribbon cable straight away from the logic board.
  18. MacBook Unibody Model A1278 DC-In Board Replacement: 步骤 18 中的图像 1,1
    • Use the flat end of a spudger to pry the hard drive cable connector straight up off the logic board.
  19. MacBook Unibody Model A1278 DC-In Board Replacement: 步骤 19 中的图像 1,1
    • Use the flat end of a spudger to pry the optical drive cable connector straight up off the logic board.
  20. MacBook Unibody Model A1278 DC-In Board Replacement: 步骤 20 中的图像 1,1
    • Disconnect the display data cable by pulling the male end straight away from its socket.
  21. MacBook Unibody Model A1278 DC-In Board Replacement: 步骤 21 中的图像 1,1
    • Use the flat end of a spudger to pry the subwoofer cable connector straight up off the logic board.
  22. MacBook Unibody Model A1278 DC-In Board Replacement: 步骤 22 中的图像 1,2 MacBook Unibody Model A1278 DC-In Board Replacement: 步骤 22 中的图像 2,2
    • Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-in side of the computer.
    • Pull the display data cable connector straight away from its socket.
  23. MacBook Unibody Model A1278 DC-In Board Replacement: 步骤 23 中的图像 1,2 MacBook Unibody Model A1278 DC-In Board Replacement: 步骤 23 中的图像 2,2
    • Remove the following two screws securing the display data cable bracket to the upper case:
    • One 7mm Phillips screw.
    • One 5mm Phillips screw.
    • Remove the two 7 mm Phillips screws from the DC-in board.
    • Lift the display data cable bracket out of the upper case.
  24. MacBook Unibody Model A1278 DC-In Board Replacement: 步骤 24 中的图像 1,2 MacBook Unibody Model A1278 DC-In Board Replacement: 步骤 24 中的图像 2,2
    • If present, remove the two 4mm Phillips screws securing the bottom case clip to the upper case.
    • Lift the bottom case clip out of the upper case.
  25. MacBook Unibody Model A1278 DC-In Board Replacement: 步骤 25 中的图像 1,2 MacBook Unibody Model A1278 DC-In Board Replacement: 步骤 25 中的图像 2,2
    • Remove the two 5mm Phillips screws securing the keyboard flex bracket to the upper case.
    • Lift the keyboard flex bracket out of the upper case.
  26. MacBook Unibody Model A1278 DC-In Board Replacement: 步骤 26 中的图像 1,1
    • Use the tip of a spudger to release the microphone from the upper case.
  27. MacBook Unibody Model A1278 DC-In Board Replacement: 步骤 27 中的图像 1,2 MacBook Unibody Model A1278 DC-In Board Replacement: 步骤 27 中的图像 2,2
    • Remove the following five screws securing the logic board to the upper case:
    • Four 3mm Phillips screws.
    • One 3.5mm Phillips screw.
    • Lift the logic board from its left edge and pull it out of the upper case.
  28. MacBook Unibody Model A1278 DC-In Board Replacement, DC-In Board: 步骤 28 中的图像 1,1
    • Disconnect the DC-In Board connector from the logic board by pulling it straight away from its socket.
结论
48等其他人完成本指南。
1指南评论
Hello, how I know that DC-In Board it´s the problem and not other part of my macbook? The magsafe is ok. Thanks!
pablo - 回复
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 67
过去 30 天: 274
总计 98,138
