当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
这个步骤还没有翻译 帮忙翻译一下
Remove the following screws securing the camera data cable and right speaker to the upper case:
One 9.9 mm partially threaded Phillips screw
One 9.6 mm threaded Phillips screw
One 4 mm Phillips screw
Slide the camera cable bracket out from under the subwoofer and remove it from the computer.
这个步骤还没有翻译 帮忙翻译一下
Grab the upper case with your right hand and rotate it slightly toward the top of the display so the upper display bracket clears the edge of the upper case.
Rotate the display slightly away from the upper case.
Lift the display away from the upper case, minding any brackets or cables that may get caught.
51等其他人完成本指南。
12条评论
I went through this because after replacing the top case, upon restart the Airport card was not recognized. I was hoping the cable had come loose, as resetting PRAM and SMC didn't fix the issue (and searching the web, a LOT of people have this issue, most without having touched the internals of their Mac). That was not the case, everything appeared correct. So I got a USB wireless dongle and called it good.
maccentric - 回复
I did it! \o/
The guide was really helpful. Be careful with all the delicate connections and DO NOT attempt to use not guide-specified tools. Yeah... You heard me, buy a decent Torx tool. :)
Thank you very much for this guide. No real problem with the good tools! After restart, the wifi comes back! Yes!!! But just a little problem … the white becomes suddenly blue and impossible to change that. I open a second time to disconnect and connect the LCD wire. It seems to be ok but after mounting the screws, my blue problem comes back! Do somebody have an idea?
