跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
This guide will show you how to remove* the hard drive from your MacBook Pro.
*Note that opening up your MacBook Pro will void any Apple warranty.
配件
没有特定配件。
  1. Turn the Macbook Pro off and unplug all power sources. There is a possibility of danger if the Macbook Pro has power when the hard drive is removed. Flip the Macbook Pro over so the Apple logo is on the table and the black laptop hinge is furthest from you.
    • Turn the Macbook Pro off and unplug all power sources. There is a possibility of danger if the Macbook Pro has power when the hard drive is removed.
    • Flip the Macbook Pro over so the Apple logo is on the table and the black laptop hinge is furthest from you.
  2. Unscrew ten screws using a Phillips #000 screwdriver. Push screwdriver into screw and then turn, keeping firm pressure on the screwdriver, to avoid stripping the screw. After unscrewing a screw, place it next to the hole it was taken from. When it is time to replace the screws this will avoid any confusion, as there are several longer screws.
    • Unscrew ten screws using a Phillips #000 screwdriver. Push screwdriver into screw and then turn, keeping firm pressure on the screwdriver, to avoid stripping the screw.
    • After unscrewing a screw, place it next to the hole it was taken from. When it is time to replace the screws this will avoid any confusion, as there are several longer screws.
    The two closest to the rear hinge are the short screws
    lucas - 回复
  3. Lift back cover off of your MacBook Pro and set aside. It might make a loud sound and that is okay.
    • Lift back cover off of your MacBook Pro and set aside. It might make a loud sound and that is okay.
  4. 任天堂 Switch 套装
    A quick fix to get back in the game
    Shop Switch Kits
    任天堂 Switch 套装
    Shop Switch Kits
  5. Locate the hard drive. With the hinge facing away from you, the hard drive can be found in the bottom left corner closest to you. It is rectangular and silver.
    • Locate the hard drive. With the hinge facing away from you, the hard drive can be found in the bottom left corner closest to you. It is rectangular and silver.
  6. Locate the black bar holding the hard drive in place. This bar is on the top of the hard drive. Loosen the two black screws on the black bar using the screwdriver. Make sure to not unscrew the silver screws.
    • Locate the black bar holding the hard drive in place. This bar is on the top of the hard drive.
    • Loosen the two black screws on the black bar using the screwdriver. Make sure to not unscrew the silver screws.
    • Pull the black bar off of the hard drive. Set it aside.
  7. Pull plastic tab to lift the hard drive out of place. Pull plastic tab to lift the hard drive out of place.
    • Pull plastic tab to lift the hard drive out of place.
  8. Carefully pull the black bar attached to side of hard drive off. This black bar will still be attached to the computer. Carefully pull the black bar attached to side of hard drive off. This black bar will still be attached to the computer.
    • Carefully pull the black bar attached to side of hard drive off. This black bar will still be attached to the computer.
结论
To install a new hard drive into this computer, follow these instructions in reverse order. Begin by unscrewing the mounting screws from the old hard drive and screwing them into the new hard drive.
If you plan to use the current hard drive as an external hard drive, leave the mounting screws in place. Purchase a hard drive enclosure to keep the hard drive in.
17等其他人完成本指南。
McKaila Ruud
于2017年03月29日注册
351 信誉积分
撰写一个指南
团队
Accidental Lekage Accidental Lekage 的会员
Meetup
3 名成员
创作了2篇指南
Great documentation, photography was very good.
Jim Brennan - 回复
wonderful, thank you very much.
Luc Constantin - 回复
Will a T6 screwdriver work to remove the screws holding the back and hard drive?
Iris R - 回复
Save the four mounting screws located on the side of the hdd . You will need them for your new hdd.I'm
James Michaud - 回复
Can I remove the old harddrive as instructed above and just have macpro use and external harddrive?
Ron - 回复
添加评论
浏览统计数据:
过去的24小时: 48
过去的7天: 355
过去的30天: 1,425
总计 25,528
