本指南有最近更改,您可查看未经巡查的最新版本。
简介
Computer running hot? Use this guide to replace a burned-out fan.
你所需要的
Remove the following ten screws securing the lower case to the upper case:
Three 13.5 mm Phillips screws.
Seven 3 mm Phillips screws.
If present, grab the plastic tab attached to the battery connector and pull it toward the front edge of the device. For Late-2011 models the battery connector will not have a tab and is simply a plug that inserts straight down into the motherboard--to remove pry the plug straight up.
Use the flat end of a spudger to lift the left fan connector out of its socket on the logic board.
32等其他人完成本指南。
2条评论
As long as I had the machine open for the battery, made sense to replace the fans. I had forgot how quite my MacBook Pro was, until I put the new fans in. Thanks ifixit!!
I had a few problems with the fan cables!!!
