跳转到主内容
MacBook Pro 17" Unibody Hard Drive Cable Replacement
你所需要的
  1. MacBook Pro 17" Unibody Hard Drive Cable Replacement, Lower Case: 步骤 1 中的图像 1,1
    • Seven 3 mm Phillips screws.
  2. MacBook Pro 17" Unibody Hard Drive Cable Replacement: 步骤 2 中的图像 1,2 MacBook Pro 17" Unibody Hard Drive Cable Replacement: 步骤 2 中的图像 2,2
    • Wedge your fingers between the lower case and the vent, and lift upward to release the two clips holding the lower case to the upper case.
    • During reassembly, carefully align the lower case and then press it firmly until both clips engage.
    • Remove the lower case.
  3. MacBook Pro 17" Unibody Hard Drive Cable Replacement, Battery: 步骤 3 中的图像 1,3 MacBook Pro 17" Unibody Hard Drive Cable Replacement, Battery: 步骤 3 中的图像 2,3 MacBook Pro 17" Unibody Hard Drive Cable Replacement, Battery: 步骤 3 中的图像 3,3
    • Whenever working near the logic board, it is always wise to first disconnect the battery to avoid short circuits.
    • If present, grab the plastic tab attached to the battery connector and pull it toward the front edge of the device. For Late-2011 models the battery connector will not have a tab and is simply a plug that inserts straight down into the motherboard--to remove pry the plug straight up.
    • If the plastic tab is missing, use a spudger to pry the connector up from its socket.
    • Pull the tab parallel to the face of the logic board.
  4. MacBook Pro 17" Unibody Hard Drive Cable Replacement, Hard Drive: 步骤 4 中的图像 1,1
    • Remove the two Phillips screws securing the hard drive bracket to the upper case.
    • These screws are captive to the hard drive bracket.
  5. MacBook Pro 17" Unibody Hard Drive Cable Replacement: 步骤 5 中的图像 1,1
    • Remove the hard drive bracket from the upper case.
  6. MacBook Pro 17" Unibody Hard Drive Cable Replacement: 步骤 6 中的图像 1,1
    • Use the hard drive's pull tab to lift it out of the upper case.
    • Don't try to completely remove the hard drive just yet! Its cable is still connected.
  7. MacBook Pro 17" Unibody Hard Drive Cable Replacement: 步骤 7 中的图像 1,2 MacBook Pro 17" Unibody Hard Drive Cable Replacement: 步骤 7 中的图像 2,2
    • Pull the hard drive connector away from the body of the hard drive.
    • Remove the hard drive from your MacBook Pro.
  8. MacBook Pro 17" Unibody Hard Drive Cable Replacement, Hard Drive Cable: 步骤 8 中的图像 1,2 MacBook Pro 17" Unibody Hard Drive Cable Replacement, Hard Drive Cable: 步骤 8 中的图像 2,2
    • Remove the following four screws securing the hard drive cable assembly to the upper case:
    • Two 1.6 mm Phillips screws securing the shield that covers the hard drive cable connector.
    • Two 2.2 mm Phillips screws securing the hard drive cable connector to the upper case.
    • Remove the shield from the logic board.
  9. MacBook Pro 17" Unibody Hard Drive Cable Replacement: 步骤 9 中的图像 1,1
    • Use the flat end of a spudger to pry the hard drive connector up and out of its socket on the logic board.
  10. MacBook Pro 17" Unibody Hard Drive Cable Replacement: 步骤 10 中的图像 1,1
    • Lift the hard drive cable out of the upper case.
结论
16等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 10
总计 20,409
