简介
Use this guide to replace a hard drive cable that is torn or has broken connectors.
你所需要的
Remove the following ten screws securing the lower case to the upper case:
Three 13.5 mm Phillips screws.
Seven 3 mm Phillips screws.
If present, grab the plastic tab attached to the battery connector and pull it toward the front edge of the device. For Late-2011 models the battery connector will not have a tab and is simply a plug that inserts straight down into the motherboard--to remove pry the plug straight up.
Remove the two Phillips screws securing the hard drive bracket to the upper case.
Remove the following four screws securing the hard drive cable assembly to the upper case:
Two 1.6 mm Phillips screws securing the shield that covers the hard drive cable connector.
Two 2.2 mm Phillips screws securing the hard drive cable connector to the upper case.
Remove the shield from the logic board.
16等其他人完成本指南。
