跳转到主内容
MacBook Pro 17" Unibody Hard Drive Bracket Replacement
你所需要的
  1. MacBook Pro 17" Unibody Hard Drive Bracket Replacement, Lower Case: 步骤 1 中的图像 1,1
    • Seven 3 mm Phillips screws.
  2. MacBook Pro 17" Unibody Hard Drive Bracket Replacement: 步骤 2 中的图像 1,2 MacBook Pro 17" Unibody Hard Drive Bracket Replacement: 步骤 2 中的图像 2,2
    • Wedge your fingers between the lower case and the vent, and lift upward to release the two clips holding the lower case to the upper case.
    • During reassembly, carefully align the lower case and then press it firmly until both clips engage.
    • Remove the lower case.
  3. MacBook Pro 17" Unibody Hard Drive Bracket Replacement, Battery: 步骤 3 中的图像 1,3 MacBook Pro 17" Unibody Hard Drive Bracket Replacement, Battery: 步骤 3 中的图像 2,3 MacBook Pro 17" Unibody Hard Drive Bracket Replacement, Battery: 步骤 3 中的图像 3,3
    • Whenever working near the logic board, it is always wise to first disconnect the battery to avoid short circuits.
    • If present, grab the plastic tab attached to the battery connector and pull it toward the front edge of the device. For Late-2011 models the battery connector will not have a tab and is simply a plug that inserts straight down into the motherboard--to remove pry the plug straight up.
    • If the plastic tab is missing, use a spudger to pry the connector up from its socket.
    • Pull the tab parallel to the face of the logic board.
  4. MacBook Pro 17" Unibody Hard Drive Bracket Replacement, Hard Drive: 步骤 4 中的图像 1,1
    • Remove the two Phillips screws securing the hard drive bracket to the upper case.
    • These screws are captive to the hard drive bracket.
  5. MacBook Pro 17" Unibody Hard Drive Bracket Replacement: 步骤 5 中的图像 1,1
    • Remove the hard drive bracket from the upper case.
  6. MacBook Pro 17" Unibody Hard Drive Bracket Replacement: 步骤 6 中的图像 1,1
    • Use the hard drive's pull tab to lift it out of the upper case.
    • Don't try to completely remove the hard drive just yet! Its cable is still connected.
  7. MacBook Pro 17" Unibody Hard Drive Bracket Replacement: 步骤 7 中的图像 1,2 MacBook Pro 17" Unibody Hard Drive Bracket Replacement: 步骤 7 中的图像 2,2
    • Pull the hard drive connector away from the body of the hard drive.
    • Remove the hard drive from your MacBook Pro.
  8. MacBook Pro 17" Unibody Hard Drive Bracket Replacement, Hard Drive Bracket: 步骤 8 中的图像 1,1
    • Remove the two 5 mm Phillips #00 screws securing the hard drive bracket to the upper case.
  9. MacBook Pro 17" Unibody Hard Drive Bracket Replacement: 步骤 9 中的图像 1,3 MacBook Pro 17" Unibody Hard Drive Bracket Replacement: 步骤 9 中的图像 2,3 MacBook Pro 17" Unibody Hard Drive Bracket Replacement: 步骤 9 中的图像 3,3
    • Tilt the outer hard drive bracket up toward the logic board and remove it from the rear case.
结论
10等其他人完成本指南。
Sam Goldheart
于10/18/12注册
471,486 声望
创作了538篇指南
团队
iFixit iFixit 的会员
Staff
118 名成员
创作了19,418篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 9
总计 4,733
