跳转到主内容
MacBook Pro 17" Unibody Feet Replacement
你所需要的
  1. MacBook Pro 17" Unibody Feet Replacement, Lower Case: 步骤 1 中的图像 1,1
    • Seven 3 mm Phillips screws.
  2. MacBook Pro 17" Unibody Feet Replacement: 步骤 2 中的图像 1,2 MacBook Pro 17" Unibody Feet Replacement: 步骤 2 中的图像 2,2
    • Wedge your fingers between the lower case and the vent, and lift upward to release the two clips holding the lower case to the upper case.
    • During reassembly, carefully align the lower case and then press it firmly until both clips engage.
    • Remove the lower case.
  3. MacBook Pro 17" Unibody Feet Replacement, Feet: 步骤 3 中的图像 1,3 MacBook Pro 17" Unibody Feet Replacement, Feet: 步骤 3 中的图像 2,3 MacBook Pro 17" Unibody Feet Replacement, Feet: 步骤 3 中的图像 3,3
    • Remove any broken or damaged feet.
    • Remove any pieces from the old foot that may have broken off in the foot hole.
    • Use tweezers to peel up and remove the old adhesive tape from the foot pad.
  4. MacBook Pro 17" Unibody Feet Replacement: 步骤 4 中的图像 1,1
    • Scrub the foot pad with adhesive remover to remove any remaining adhesive.
  5. MacBook Pro 17" Unibody Feet Replacement: 步骤 5 中的图像 1,1
    • Wipe the foot pad with an alcohol prep pad to remove any residue left by the cleaner.
  6. MacBook Pro 17" Unibody Feet Replacement: 步骤 6 中的图像 1,1
    • Peel a replacement foot from the plastic backing.
  7. MacBook Pro 17" Unibody Feet Replacement: 步骤 7 中的图像 1,3 MacBook Pro 17" Unibody Feet Replacement: 步骤 7 中的图像 2,3 MacBook Pro 17" Unibody Feet Replacement: 步骤 7 中的图像 3,3
    • Align the new foot inside the foot pad.
    • Make sure the alignment nub on the foot is lined up with the small hole near the perimeter of the pad.
    • Lay the foot down while keeping it properly aligned.
    • Check for proper alignment from the inside of the lower case. Use tweezers to slide the alignment nub so it lines up with the hole.
  8. MacBook Pro 17" Unibody Feet Replacement: 步骤 8 中的图像 1,1
    • Press the new foot down firmly with your finger and maintain pressure for 30 seconds to set the pressure sensitive adhesive. Support the other side of the cover while you press the foot down.
    • Repeat the last six steps for any broken or damaged feet.
结论
To reassemble the device, replace the lower case and all of the screws.
9等其他人完成本指南。
Arthur Shi
于01/03/18注册
249,876 声望
创作了503篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,732篇指南
一条评论
I’m not sure if you really need to remove the lower case. It doesn’t really hurt it to do it though, give you a chance to blow out the accumulated dust.
snoakes1 - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 12
总计 2,228
