跳转到主内容
MacBook Pro 17" Unibody fixing noise fan and overheat
你所需要的
  1. MacBook Pro 17" Unibody  fixing noise fan and overheat, Before starting: 步骤 1 中的图像 1,1
    • I am using Husky screwdrivers HD 74501 U & HD 74502 Y
  2. MacBook Pro 17" Unibody  fixing noise fan and overheat, Getting ready: 步骤 2 中的图像 1,1
    • Turn your MBP upside down
  3. MacBook Pro 17" Unibody  fixing noise fan and overheat, Screws first: 步骤 3 中的图像 1,1
    • Remove the screws from the back cover
  4. MacBook Pro 17" Unibody  fixing noise fan and overheat, Open it !: 步骤 4 中的图像 1,1
    • Carefully open the back cover.
  5. MacBook Pro 17" Unibody  fixing noise fan and overheat, Dust ? No, thanks !: 步骤 5 中的图像 1,1
    • Remove the dust . I am using a vacuum cleaner here with a brush.
  6. MacBook Pro 17" Unibody  fixing noise fan and overheat, Apple warranty: 步骤 6 中的图像 1,1
    • Keep your Apple warranty by disconnecting the battery and DO NO TOUCH any electronic parts and chips ! Also touch any metal item to unload the body static.
    • Keep your Apple warranty and disconnect the battery.
  7. MacBook Pro 17" Unibody  fixing noise fan and overheat, Disconnect the fan: 步骤 7 中的图像 1,3 MacBook Pro 17" Unibody  fixing noise fan and overheat, Disconnect the fan: 步骤 7 中的图像 2,3 MacBook Pro 17" Unibody  fixing noise fan and overheat, Disconnect the fan: 步骤 7 中的图像 3,3
    • Disconnect the fan from the mainboard.
  8. MacBook Pro 17" Unibody  fixing noise fan and overheat, Almost there !: 步骤 8 中的图像 1,1
    • Remove the 3 screws that fron the fan fixture.
  9. MacBook Pro 17" Unibody  fixing noise fan and overheat, Take a walk on the wild side !: 步骤 9 中的图像 1,1
    • Clean the dust with a very soft toilet paper.
  10. MacBook Pro 17" Unibody  fixing noise fan and overheat, Finally!: 步骤 10 中的图像 1,1
    • This is what I´ve found inside one fan !
结论
13等其他人完成本指南。
LAOMUSIC ARTS
于02/25/17注册
613 声望
撰写一个指南
6指南评论
I’d be careful about using a vacuum cleaner on the inside of the computer as it can cause static discharge and zap your components.
pov - 回复
Thanks a lot s
Sanzi Gao - 回复
Sanzi Gao - you are welcome!
LAOMUSIC ARTS - 回复
@laomusicarts do you know where I might be able to get an HD-74501 screwdriver. New or Used?
Kendall Lui - 回复
Since my 2008 Macbook Pro has been overheating for a while I tried this. Unfortunately everything inside is quite clean: no dust in the fans or heat-sinks.
The fans run quite well , and get going pretty fast as the device heats up. Any other ideas are welcome, This was a GREAT machine and I miss using it.
Eric Hammond - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 40
总计 10,026
