简介
The time and date, as well as other settings, are kept by the PRAM battery when your machine is off.
你所需要的
Use your fingers to push both battery release tabs away from the battery and lift the battery out of the computer.
Remove the four identical Phillips 3.4 mm screws from the memory door. These screws have 4 mm diameter heads rather than the 3 mm heads on the body screws.
Remove the three Phillips screws in the battery compartment near the latch. Apple was nice enough to tilt these screws at a slight angle to make them easier to remove. On the A1261 these screws have 4 mm diameter heads rather than the 3 mm heads on the body screws.
Disconnect the orange SuperDrive ribbon cable from the logic board, removing tape as necessary.
Disconnect the PRAM battery cable from the bottom right corner of the logic board.
6等其他人完成本指南。
