本指南有最近更改,您可查看未经巡查的最新版本。
简介
This guide is an internal prerequisite.
你所需要的
Use the flat end of a spudger to carefully peel off the three antenna straps stuck to the lower edge of the LCD.
While pulling the clutch assembly away from the clutch hinge with one hand, insert an iPod opening tool between the clutch cover and the front display bezel to lift the clutch cover over the retaining pin on the front display bezel.
Pull the clutch assembly away from the front display bezel.
即将完成!
结论
