介绍
This guide is an internal guide used as a prereq.
配件
没有特定配件。
  1. Use the flat end of a spudger to pry the AirPort/Bluetooth ribbon cable connector up off the logic board.
    • Use the flat end of a spudger to pry the AirPort/Bluetooth ribbon cable connector up off the logic board.
  2. Disconnect the camera cable by pulling its connector away from the socket (toward the optical drive) on the logic board.
    • Disconnect the camera cable by pulling its connector away from the socket (toward the optical drive) on the logic board.
  3. Android 维修工具包
    一个新的屏幕或电池就在一个套件之内。
    现在开始购物
    Android 维修工具包
    一个新的屏幕或电池就在一个套件之内。
    现在开始购物
  4. Use the flat end of a spudger to pry the optical drive connector up off the logic board.
    • Use the flat end of a spudger to pry the optical drive connector up off the logic board.
  5. Remove the two Phillips screws securing the AirPort/Bluetooth board housing. Carefully rotate the AirPort/Bluetooth board housing (with AirPort/Antenna cables still attached) out of the lower case.
    • Remove the two Phillips screws securing the AirPort/Bluetooth board housing.
    • Carefully rotate the AirPort/Bluetooth board housing (with AirPort/Antenna cables still attached) out of the lower case.
  6. Remove the following three Phillips screws securing the optical drive to the upper case:
    • Remove the following three Phillips screws securing the optical drive to the upper case:
    • One 4.5 mm Phillips screw securing the optical drive bracket to the upper case near the fan.
    • Two 2.5 mm Phillips screws securing the optical drive to the upper case near the optical drive opening.
  7. Lift the optical drive near its connector and pull it away from the upper case to remove it from the computer.
    • Lift the optical drive near its connector and pull it away from the upper case to remove it from the computer.
结论
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 885
