简介
Replacing a defective fan is pretty easy and will keep your laptop running cool.
你所需要的
Remove the following ten screws securing the lower case to the upper case:
Seven 3 mm Phillips screws.
Three 13.5 mm Phillips screws.
56等其他人完成本指南。
4条评论
Merci à iFixIt pour la qualité des pièces fournies et la rapidité à laquelle elles ont été expédiées.
Merci à Walter pour la clarté de son tuto, et aux traducteur pour la traduction !
Que du bonheur !
Hello Walter, I have a mid 2009 macbook pro 15” and it has only one fan. I need to replace it. Which one should I buy?
Same thing I said for the left fan:
Great guide, easy work to do! If I can do this, anyone can. If I can do this, someone who does not exist almost can. Not quite! But almost. I was happy to get that squalling and howling old fan out of my MacBook Pro, and thereby to end the squalling & howling I got from my family over the noise it made. Like the old one, the new fan works great, but it is new, and quiet, and I am thankful. Happy customer.
May be helpful to have more distinct colors to identify the different screws.
Victor Caamano - 回复
