跳转到主内容
MacBook Pro 15" Unibody Mid 2009 RAM Replacement
你所需要的
  1. MacBook Pro 15" Unibody Mid 2009 RAM Replacement, Lower Case: 步骤 1 中的图像 1,1
    • Seven 3 mm Phillips screws.
  2. MacBook Pro 15" Unibody Mid 2009 RAM Replacement: 步骤 2 中的图像 1,2 MacBook Pro 15" Unibody Mid 2009 RAM Replacement: 步骤 2 中的图像 2,2
    • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
  3. MacBook Pro 15" Unibody Mid 2009 RAM Replacement, RAM: 步骤 3 中的图像 1,2 MacBook Pro 15" Unibody Mid 2009 RAM Replacement, RAM: 步骤 3 中的图像 2,2
    • Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM.
    • These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • After the RAM chip has popped up, pull it straight out of its socket.
    • Repeat this process if a second RAM chip is installed.
结论
159等其他人完成本指南。
5条评论
I bought and installed 4GB x2 RAM for my Mid 2009 15 inch MacBook Pro and it was easy and is working great. Before this I had 4GB and it was being maxed out. It was very easy. I did purchase the required tools which made it simple. I also swapped the battery at the same time. I am writing this from the same computer and it is working well. Good luck!
1tom2go - 回复
I had no trouble installing the 4 GB RAM I bought for my Mid 2009 15 Inch MacBook Pro. The mistake I made though was not realising that my machine has two RAM slots. I only bought one chip! So now I have to buy another one.
If you read this before you buy some RAM, make sure you check how many slots your computer has!
Also, I must say the customer support from ifixit is great. I messaged them about this and some other issues I was having and I got a detailed response from them within a couple of days. Thanks guys!
oliverbarrand - 回复
Thanks! You saved my life.
saltyhf - 回复
I replaced my original 2x 2gb ram with 2x 4gb RAM following your instructions. However, upon boot up, it’s only showing 1 of the 2 4gb chips. Any tips on how to get both seated correctly?
Matthew Longo - 回复
Never mind. I was able to pop the second chip back out and get it seated properly.
Matthew Longo -
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 25
过去 30 天: 69
总计 61,683
