简介
Use this guide to replace a blown-out microphone.
Remove the following ten screws securing the lower case to the upper case:
Seven 3 mm Phillips screws.
Three 13.5 mm Phillips screws.
Remove the two 5-Point Pentalobe screws along the top edge of the battery.
Use the flat end of a spudger to pry the microphone cable connector up off its socket on the logic board.
2等其他人完成本指南。
