本指南有最近更改,您可查看未经巡查的最新版本。
简介
Accessing the RAM in this computer is straightforward and requires minimal disassembly.
你所需要的
With the case closed, place the Unibody top-side down on a flat surface.
Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
Grab the translucent plastic tab and pull the battery up and out of the Unibody.
If the latch is depressed it will lock the battery in place.
Remove the following eight screws securing the lower case to the chassis:
One 5.4 mm Phillips screw.
Three 14 mm Phillips screws.
Four 3.5 mm Phillips screws.
187等其他人完成本指南。
10条评论
Thank you ifixit. It was a breeze... 8Gb in the house... Best Regards
Hi Bruno!
Assuming you still have the MBP, I am curious to see what memory you installed to get 8 gigs. I just installed 2 X 4 gigs of Kingston PC3 106000 SODIM and my MBP does not want it. My tech assured me that if anything would do it, it was this memory.
Suggestions?
Thank you!
Ghislain
Ghislain -
As a breeze. Man, was my computer dirty! Now my computer feels like it's on amphetamines! Lol. So happy the pinwheels are gone. I can finally get work done and feel right about charging my clients hourly!
Installed 8GB of RAM without problems. :)
Been wondering if this system would support 16GB though, given that appropriate modules seem to be on the market, that it has a 64 bit EFI and that the never versions of OS X, booted in the 64 bit kernel (which has been the default mode for a few years, now) obviously support that and more…
