跳转到主内容
修复你的物品
维修的权力
商店
配件
没有特定配件。
  1. Disconnect the camera cable by pulling the male end straight away from its socket.
    • Disconnect the camera cable by pulling the male end straight away from its socket.
  2. Deroute the camera data cable from the channel in the optical drive.
    • Deroute the camera data cable from the channel in the optical drive.
  3. Use a spudger to pry the optical drive connector straight up off the logic board.
    • Use a spudger to pry the optical drive connector straight up off the logic board.
  4. Remove two 8 mm Phillips screws securing the camera cable bracket to the upper case. The rightmost screw may remain captive in the camera cable.
    • Remove two 8 mm Phillips screws securing the camera cable bracket to the upper case.
    • The rightmost screw may remain captive in the camera cable.
    • Lift the camera cable bracket out from the upper case.
  5. Remove the following three Phillips screws securing the optical drive to the upper case:
    • Remove the following three Phillips screws securing the optical drive to the upper case:
    • One 3.5 mm Phillips screw.
    • Two 2.5 mm Phillips screws.
  6. Lift the optical drive from its left edge and pull it out of the computer.
    • Lift the optical drive from its left edge and pull it out of the computer.
结论
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 1,210
