简介
Use this guide to replace the hard drive bracket nearest the front edge of your MacBook Pro 15" Unibody Late 2008 and Early 2009. This bracket also contains the infrared sleep sensor and its cable.
你所需要的
With the case closed, place the Unibody top-side down on a flat surface.
Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
Grab the translucent plastic tab and pull the battery up and out of the Unibody.
If the latch is depressed it will lock the battery in place.
Remove the following eight screws securing the lower case to the chassis:
One 5.4 mm Phillips screw.
Three 14 mm Phillips screws.
Four 3.5 mm Phillips screws.
Disconnect the camera cable by pulling the male end straight away from its socket.
Using the flat end of a spudger, pry the subwoofer connector straight up off the logic board.
Remove the single Phillips screw securing the hard drive bracket to the upper case.
Use the pointed end of a spudger to flip the lock on the ZIF connector.
另外一个人完成了本指南。
