跳转到主内容
MacBook Pro 15" Unibody Early 2011 Battery Connector Replacement
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. MacBook Pro 15" Unibody Early 2011 Battery Connector Replacement, Battery Connector: 步骤 1 中的图像 1,2 MacBook Pro 15" Unibody Early 2011 Battery Connector Replacement, Battery Connector: 步骤 1 中的图像 2,2
    • For certain repairs (e.g. hard drive), disconnecting the battery connector is not necessary but is recommended as it prevents any accidental shorting of electronics on the motherboard. If you do not disconnect the battery connector, please be careful as parts of the motherboard might be electrified.
    • Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
    • It is useful to pry upward on both short sides of the connector to "walk" it out of its socket.
  2. MacBook Pro 15" Unibody Early 2011 Battery Connector Replacement: 步骤 2 中的图像 1,1
    • Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 10
总计 620
